I must have pressed the wrong button! Previous post shows my horizontal grinder - not pretty but it does the job.
A few notes you might find useful:
It would be good to have the small wheel attachment on a sliding tool arm, I have to take up slack belt by re-positioning the tracking pulley and/or the small wheel attachment. This is why the tracking pulley spring is clamped. Some sort of sliding spring anchorage would be easier but a sliding tool arm would be even better. If possible you could angle the tool arm so whatever size small wheel you have fitted the belt runs onto the platen properly - (not angled as shown) This would save having to move the platen. There must be a way of calculating this angle.
I fitted the work table around the drive pulley but never use it as it chatters too much, with a rubber drive wheel it might be use-able.
The way my main work rest is fitted it always ends up rotating around the fixing post (inboard of the belt), this is worse if using a fence clamped to the work rest. Something to resist torque would be good. Obviously easy, quick, accurate and repeatable height and angle adjustment would be fantastic
In a previous post I talked about using 3 inch deep pulleys as you could move the belt instead of raising/lowering the work rest. You can still do this to a certain extent with 2 inch pulleys by running the belt off the edge but you need to allow space below and above your pulleys for the belt to overhang. You can see on my grinder where the belt has cut into the grinder base plate.
I would strongly recommend using a 2.5 to 3 inch pulley on your small wheel attachment so you do not have to fine tune your tracking for the belt not to wear your bearings or bearing supports. Alternatively make sure you have a small wheel of a diameter sufficient for the belt to clear your bearings/bearing supports and use this when working on other wheels/platens. Pic below shows the problem.
And just for your interest, my largest and smallest contact wheels
The smaller one does just about work with flexible belts but you do have to run the machine slow and time your grinding to avoid the joints.
I will be following your progress with interest - I have the urge to build another one myself now
