- Feb 23, 2001
During the peak of Roman civilization, it was not uncommon to see armor made out of hotwaxed leather. This leather was not supple or soft but hardened and a better defense against a blade than bare skin alone. Over time, other civilizations picked up this technique and it helped make leather more resistant to moisture and abuse. Though time has passed, the method of producing hot waxed leather is virtually unchanged. Heat leather to open the pores then expose to melted beeswax and polish smooth. If you wish to have a more durable and water resistant sheath or one more resistant to accidentally cutting follow this quick tutorial how to hotwax and achieve the same results. I'm using pure beeswax to treat my edge cover for my Gransfors Bruks mini-hatchet.
Step 1, you'll need the following. Beeswax, toothbrush, a container to melt wax in, pot with water and some old rags
Step 2, melt beeswax in an old pot and preheat your oven to anywhere between 225 degrees to 300. You won't be cooking your leather, just warming it.
Step 3, put your leather in the oven to open the pores. You can also use a hair dryer or heat gun but the oven works best in my opinion. About 5 to 10 minutes is sufficient.
Step 4, coat your leather with as much beeswax as it can take. Don't worry if it dries on the leather. You will be placing it back in the oven shortly.
Step 5, place your beeswax covered sheath or axe cover in this case back in the oven. This will help the leather soak up all the beeswax. Don't remove it from the oven until the wax all melts.
Step 6, make sure both sides of your sheath are coated. Careful touching any exposed metal parts as they will be hot from the oven. Place back in the oven.
Step 7, remove your sheath from the oven and attempt to put more wax on it. Recoat as much as necessary. Handle with care. The leather will appear damp and much darker during the process.
Step 8, use an old rag to handle the sheath. You can better shape it to the contours of the blade this way.
Step 9, you can use a synthetic cloth to polish the leather and buff it to a better shine. I use an old synthetic running shirt and it really makes it smooth and brings it to a nice finish.
Remember, when hotwaxing, you will likely change the color of your leather. If you can live with the change, you'll end up with one hell of a durable sheath. If it was good enough for the gladiators, beeswaxed leather is good enough for me!
