- Mar 8, 2008
When doing more than just a quick power-grinding I like to keep a spray bottle of water handy and have it set to a fine mist. It gives more uniform coverage and works faster at drawing out the heat. Platen grinding is generally worse in terms of heat buildup than contact wheel grinding or slack belt grinding since the stationary platen is continuously experiencing friction. A ceramic platen can help with that vs. a steel one. Something like a flap wheel would probably do pretty well in terms of keeping the heat down, while the solid backing of a flap disk tends to necessitate a lighter touch and fresher abrasive to work properly without causing rapid overheating.
