- Nov 28, 2014
How are you measuring your edge thickness before sharpening and do you have a tolerance? +-.001”?
Happy thanksgiving!!!
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Micrometer . I set desired thickness on Micrometer and if edge catch in , I m there ..................How are you measuring your edge thickness before sharpening and do you have a tolerance? +-.001”?
They are little inconvenient to measure the edges . I m never sure that i measured right edge thickness with them .
That’s the kind of stuff I’m looking for. I will get a dedicated pair of calipers and try and make a stop on one jaw about .005” up and always measure with the edge resting on that. That will give you a real close idea of what your “behind edge” thickness is after sharpening.it makes a big difference how far up you measure which is why it hard to measure exactly. This also depends on the grind. A FFG 2" chef knife vs a low bevel saber. Usually I take my knifes till they're forming a burr and then case the edge back to the thickness I want.
I would be handy to glue a little stop on the caliper right at the edge so you always measure a consistent depth in from the edge.
It is much easier to calculate BTE and it will be 100 % accurate .Real close idea of what BTE thickness will be , depend on sharpening angle too.So where you think that you need to measure on 0.20mm thick edge and 25 degree sharpening angle to get 0.30mm BTE ?That’s the kind of stuff I’m looking for. I will get a dedicated pair of calipers and try and make a stop on one jaw about .005” up and always measure with the edge resting on that. That will give you a real close idea of what your “behind edge” thickness is after sharpening.
I use digital calipers and measure at the transition point from the primary to secondary bevel. It's important to specify what the edge angle is at when you do measure though... An edge .010" thick at 20 dps will be much thicker than an edge .010" thick at 15 dps. Most people miss this point.
