If you like the look, check out some of the copper/carbon steel mokume. Ariel has some nice pieces.... I played with making it a little. Tempermental to say the least. The copper likes to squirt.
You have to use thin steel, shim stock and the like, with thin copper layers or copper wire in the stack. Put it all in a box with a little flux in the mix, and then heat it all up. Once it gets to temp, the copper flows into all the little nooks and crannies and can all be squished flat. Pretty much requires a press. Hammer blows are a recipe for squirting copper.
I saw an example of a chunk of cable heated up and opened a slight amount. Basically the reverse of what is done prior to hammering a cable billet. Then the cable is brought back up to forge welding temps and dunked in a crucible of molten copper. More or less quenching the steel in the molten copper I guess. I can't find the pics right now but the resulting 'billet' was successfully drawn out from there. I don't know how messy the whole affair was but the stuff sure looks neat when it is etched and polished up.
Ariel had a how to on here at one point. My tapatalk stinks for searches and PM's lately. But I'd bet it would still pop up.
Of course I'm off on a different pony at this point.
-Eric
