HELP!
The skin is left and I want to tan it so someone can make a few belts for me. How do I do it with household items? Any kits you recommend?
How fresh is the skin?
Have you salted it immediately after you skinned it? If so, how long has it been salted for?
Before you tan the snake skin, I suggets you remove the scales first by soaking it in a lime bath (using fresh calcium hydroxide, also known as slaked lime or hydrated lime). If the scales are left on they can curl up later on and effect the feel of the leather produced. Both fresh and salted skins can be descaled in a lime bath.
The following mix will dehair / descale 7kg (approx 15 lb) of hides / reptile skins:
To a 50 litre container add 35 litres of soft water, 2kg slaked lime powder and 3.5kg salt (roughly in a 10 gallon container add 8 gallon soft water, 4lb slaked lime and 8lb salt). Try and keep the bath relatively cool (15 degrees celcius is ideal :thumbup: )
Obviously adjust these quantities (keeping the same relative proportions) according to the weight of the snake skin you want to prepare.
Check the skin after 3 days to see if the scales come off easily. If they don't, leave it for a little longer,
BUT no more than a total of 5 days in the bath.
Remember to wear rubber gloves and immediately wash off any of the lime bath that makes contact with your skin.
Once the skin is descaled, throughly wash the skin in fresh water. Once washed, immediately start fleshing the skin to remove any flesh and membranes from the inside of the skin so the tanning solution can penetrate the skin. Once fleshing is finished, give the skin a wash in a water and detergent solution, rinse with fresh water and then soak it in vinegar for 15 minutes (this will neutralise any residual lime left from the descalling procedure).
Remove the skin, rinse with fresh water again and place it immediately into the tanning solution. You can make your own from any tree bark that contains lots of tannin, but the easiest way would be to buy a commercail tanning solution and follow the instructions on the pack.
It's hard for me to suggest a kit as I don't know here you live, but I'm sure a google type search for "tanning solutions" would indicate those available in your area.
Hope this helps.
Kind regards
Mick
