- Jun 8, 2005
It is only science if it can be recreated and repeatedly tested on this and other materials, otherwise any conclusion, is just idle speculation.
n2s
The falsifiability criterion of science has some legitimacy, but I think the issue with the unstated conclusion here is that there is an implicit premise--that the test can't be or hasn't been repeated. The falsifiability criterion doesn't demand that actual repeat tests be performed. It only demands that it's logically possible for repeat tests to be performed. Otherwise, the original results can't even hypothetically be falsified.
At any rate, this test could be repeated. So the criterion is satisfied. We have a scientific result. We know that THAT particular sword can survive a full impact on that PARTICULAR PART of the CUTTING EDGE from a PARTICULAR ROUND fired from THAT INDIVIDUAL gun. So we do have a good result here, but it's quite limited. Repeat testing with different guns, swords and other factors would give you a much broader and more useful result.
Besides, there are many more factors to the steel that aren't even being discussed. I'd pretty much guarantee that 440C will be more rust resistant than even the nicest traditional blade.
Those miscellaneous factors aside, I find this to be a rather simple question to answer. If the question is "do modern steels compete with traditional Japanese sword making." The answer to this is probably no. As far as I'm aware, no one's investing vast amounts of money into developing super steels to perform in full combat situations against other people with hardened steel katanas and samurai armor.
If the question is, however, can modern technology hypothetically exceed traditional Japanese sword making? The answer is obviously yes; traditional Japanese sword making has gone through many technological improvements over the many century history of the (recognizable) katana--the new innovations even 400 years ago surpassed the technology of a hundred years before that. There's no reason, in principle, that modern technology, with sufficient research and investment, wouldn't exceed yesteryear's designs.
The question effectively boils down to: did the Japanese actually finalize the perfect steel for katanas--a steel that could not ever be improved--and I see no reason to believe that's the case. Certainly the traditional swordmakers didn't think so.
