I posted the following question to the maker of my snake-skin sheaths and got the noted reply:
Al & Karen,
I have 2 sheaths from you and another on the way & like them a lot, but I wonder how I should care for the snake-skin part of the sheath. I went onto a sheath forum and got some suggestions but the people there weren't sure. Someone asked if you left the scales on and I answered "yes," was that right?
Lawrence Helm
Hi Mr. Lawrence, we appreciate your purchases, and glad you are happy with the sheaths.
The scales are on the snake skin. It was glued down with contact cement and them he
applied it to the top also. He applied a final coat of Fiebing Resolene acrylic finish that makes
it water repellent. I would only use a water dampened lent free rag and wipe downward gently
as not to snag the scales. You can apply some more of the Resolene to it if you think it needs
more. You should do the leather part and let it dry one day and do the snake skin the next
with the Resolene if needed. or you have a accident. We use Fiebing's oil dye also. You can use
Neatsfoot oil to soften and keep the leather from drying out,don't get it on the snake skin.
Anything with alcohol will ruin the finish, so only use leather cleaning products. Hope this
helps and thanks again Al and Karen.
- alscrafts
Despite liking the two sheaths I got from Alscrafts (for my Buck 119 and 124) I liked the style of another snake-skin sheath maker for my 120. That one, while made well enough has caused me a problem. The sheath was tightly made and perhaps patterned for the older style 120 which has a slightly different blade shape than the 120BR. In any case the first time I inserted my 120BR into the sheath it poked a tiny hole in the back side of the sheath. I immediately order a 120 sheath from Alscraft but kept playing with the one I'd received. If I am careful and worm the 120BR toward the outside a bit I can keep it away from the flap that must now be inside that would guide it toward the little hole.
After the above communication from alscraft I can see that the other sheath maker didn't apply Resolene. It is possible to flip up the snake scales with my fingernail; so I'm not going to subject it to a hike until I get some Resolene on it. As to the little flap that is now inside the sheath near the tip, I don't know what to do about that other than hope for the best.
Lawrence
