How do you carry your Izula for EDC?
I dont like the neck carry and i wear alot on my belt. Any pocket carry methods/sheaths? thks.
In the stock sheath, in my change pocket. Fits perfect, and easily accessible. Paracord in a cow hitch around a belt loop.
i carry it in a back pocket sheath or around my neck.
i improved the design abit when i made this one for a friend
back pocket makes for a very comfortable carry
cricket
cricket[/QUOT
Would that work in a front pocket as well? I need it concealed.
front pocket is a little more trickey, depends on the pants. i've been thinking about designing one with a pocket clip that holds it deeper in the pocket. but again it comes back to what kind of pants, jeans have smaller pockets than cargo pants or slacks. also i'm not too keen on getting poked in the nuts every time i sit down. maybe just take a nylon strap and a small pocket clip and screw it to the stock sheath. someone did that the other day looked like a good idea to me.
take it easy
cricket
front right pocket with the sheath pressed against my wallet. i work in an office so leaving it on a teklok on my belt isn't really doable.
Mine is attached with a tek-lock to my belt at the appendix, handle down, angled slightly toward my hip. The draw is really easy, just a swift downward + outward motion.
On a cord around my neck, under either a tech t-shirt or a tech golf-shirt.
If you guys man up and carry the pink one, nobody sees it as a knife :D
you could carry around your neck and over one shoulder so it hangs under your armpit.
the problem with this is that you can only reach it with one hand, defeating one of the big advantages of normal neck carry.
front pocket carry with a paracord leash from the sheath to the belt seems like it should work well, and probably better with one of the one-piece, folded kydex sheaths from Hoopster or Shotgunner. they seem a but slimmer than the stock sheath
cricketdave's pocket sheaths look nice, but i usually wear 5.11 cargo pants because i love the pockets and they actually fit me (i have a 33" waist and 36" inseam... and i'm tired of "floods") but the rear pockets are very deap, so that wouldn't work with pants like these.
I usually carry it in the factory sheath also.. either in one of my back pockets or my right front pocket.
right front pocket with an esee-3 boot clip. or neck carry over my shirt with a KSF sharpshooter sheath.
Front pocket, paracord between the "long hole" on the sheath and a belt loop.
If in a hurry: Pull knife out by handle, once paracord becomes taut, the knife comes out of the sheath. Fast and you don't lose the sheath.
Picked up a kydex sheath from hoopster, here on bladeforums. Works really well, and can be changed up to be used in other carry positions as well.
