knowtracks
- Jan 16, 2006
The problem, as has been stated is the height of the kick. It can be adjusted either way, up by filing the bottom of the kick if the blade sits to high or down if the blade is hitting the back spring, as in this case. If you place the tang on the edge of an anvil, vice or something else that is hard and stable then take a flat nosed punch, placing it towards the bottom of the kick and hit it with a hammer. By smashing the tang sideways it elongates the very end where it rests on the backspring. You will have to experiment with how much force, how big a hammer to use in order to get the required results, I personally start out with less force and work my way up until the blade no longer hits the backspring. BUT by moving the height of the kick, in either direction you are also changing where the backspring sits in the closed position!!
Dave
Dave
