How do you finish Purpleheart to keep it purple?
Our local woodzone store has some 2" x 2" x 60" Purpleheart for sale cheap ($5.99). How can i finish this as a knife handle to keep the purple from fading out to a brown? Has anyone finished Purpleheart and kept the purple color for several years?
Thier website has this:
Botanical Name:
Peltogyne spp.
Other Names:
Violetwood, Amaranth, Sakavalli, Pau Roxom Nazareno, Armante, Tananeo, Saka.
Natural Characteristics: Straight grain with a moderately coarse texture.
Color:
Deep purple. Color changes to a rich brown as the wood matures.
Workability:
Can de difficult to work with.
Tends to blunt cutters.
Cutters must be very sharp or they can burn the wood.
Purpleheart must be run very slowly through the machines.
Finishing
Qualities:
Finishes well.
Lacquer based finished will preserve Purpleheart's purple color.
Alcohol based finishes will remove it.
Durability:
Uses:
Veneers, turnings, furniture, tool handles, etc.
Comments:
Purpleheart can have quite a bit of gum and sap in it that tends to leak out when the wood is heated by cutters. Because of this care should be take to ensure your blades are very sharp.
Price: Moderate
I made a picture frame out of it around 8 yrs ago and it still looks pretty purple to me. I think I just gave it a tung oil finish. Hard handling/use may leach out some color, but not that I've seen. If you are real concerned, I would go with a hard, clear finish.
Good luck,
Nathan
It turns more purple with exposure to air. If you hit it with a heat gun, or quickly with a torch, it turns a deep purple.
I have used purpleheart quite a bit in making martial arts dummies. I use a spar varnish with UV protection. UV is what turns the wood purple... and unfortunately what will also fade the purple over time. Sand your wood down, then let it sit until it is a bright purple. Apply several coats of varnish with UV protection. Might not be the best solution for knife handles though.
I finish purpleheart knife handles with Johnsons paste wax.
it holds up reasonably well, eventually it will brown out with handling, a light sanding and rewaxing restores the color
-Page
I've finished by knives with Butcher's wax with great results. Two knives I've seen recently are still as purple as they were four years ago.
I like Watco's Teak Oil. Did several Purplehearts a few years ago, and last I heard they're still purple. I've some scales that have been laying around for around 2 years that are deep purple now.
In this link, they tell you how to change the color of purpleheart with heat. I used my kitchen oven to get the desired color, then sent it out to WSSI for stabilizing. After it came back, I cut into the stabilized wood, and the color was still there. Only time will tell if it will retain the color for the long run.
By the way, Hypocrite, those are some incredible wooden dummies.
My daughter's favorite color is purple, so I made her this knife with purpleheart and some of Aldo's 1095.
Just used a couple coats of Formby's Tung Oil Finish; so far, so good.
Heat will make the color darker.
- Mitch
Very good info. Troop that is the kind of handle i think i am trying for. I did try heatting a small piece in my toaster over to 400 degrees, and it did darken it some, but around the layer rings a really dark purple started bubbling out, i guess this stuff is not dry enough to get a good color from heat yet. But i will try it on a handle shape piece soon just to see. :D
It's kind of "hit or miss" with this wood. If I were you, I'd just let it darken by itself a little. Also, I would stabilize it, in one form or another, before you work it. Watch that you don't burn it on the belts.
- Mitch
I've used purple heart quite often, and it will darken with age. I've found that sunlight is what has the greatest effect on the darkening of the wood.
I cut a bunch of it up into handle slabs about 5 years ago, and they actually turned a purplish grey color over time. Careful sanding brings them back to a rich purple color. Heat will definitely darken purpleheart to almost blackish purple. I'm attaching two photos. One is the Christmas knife I made this year for the Bladeforums gift exchange. I used a "Purpleheart Medal" theme and overheated the mosaic pin in the handle to put a bleeding dark purple look to the area around the pin. You can see how easy it is to get a dark purple. The other photo is the kitchen cutlery set I made for my wife for Christmas this year. This is the as finished look of the knives. I put 6 coats of gunstock oil on the handles and butcher block (purpleheart and hickory), and then put two coats of Walkers Wax on all of it. The handles of the cutlery set are from curly purpleheart that I had purchased about 10 years ago and was waiting for just the right project to use it on.
A few years back I remember Don Cowles suggesting the use of Armorall to stop woods that darkened when exposed to sun light. Its got UV protection. I tried it a couple times but can't remember if it worked or not. Rose colored glasses also help.
I've heard of the armorall idea; I haven't tried it myself, though (I just try to avoid purpleheart).
You can do interesting things to the color with acid exposure. HCl will turn the wood hot pink, (kinda fun). Purpleheart is very chemical resistant, and is used for chemical vats.
Phillip
Is it just me or is $5.99 an awesome price for 5 feet of 2"x2" purpleheart? I'd nab that in a heartbeat, personally.
Gavin
I was going to go back if i got off work early today and grab a few more sticks, and they have some eepee (sp?) and yellow heart also, for cheap also. but it appears i have to work all day today :(
If anyone near me needs purpleheart for a project, I have about 75 pieces that are about 2"x2"x5+" and two additional boards that are 2"x14"x12 feet. I'm thinking about sending a bunch to WSSI.
