I have been sharpening a Henckels kitchen knife at 15 degrees per side using a 400 grit diamond stone with edge-trailing strokes. Once the bevel has been re-established, I have been using a 1.4 micron ceramic stone to remove any burrs. The ceramic stone is used at 18 degrees per side with a few very light, edge-leading strokes per side. My goal is to deburr the edge in a way that has a minimum impact on the "toothiness" of the edge.
After each stroke with the ceramic stones, I have been checking the sharpness of edge by lightly pulling my fingertips across the blade in a direction that is perpendicular to the edge. I have noticed that, when I begin deburring and I use the ceramic stone on the right side of the edge, the edge feels sharper to the fingers on my right hand than it does to the fingers on my left hand. I think what is happening is that, when the ceramic stone is first used on the right side of the edge, it pushes the burr over towards the left side of the edge, and the fingertips on my right hand feel the burr more because it is leaning towards the left. The opposite happens when I use a ceramic stone on the left side of the edge.
I continue the alternating, edge-leading strokes with the ceramic stones until the edge feels equally sharp to the fingers on both hands (ie the burr is gone and only the bevel remains). I then do several slicing cuts through newspaper to make sure that I don't have a wire edge.
My first question is whether I should use a coarser stone, like the 3000 grit diamond stones, to deburr so I can reduce the number of strokes required on each side (it currently takes 5-6 strokes per side)? My second question is whether the coarser stone would have a negative impact on the coarseness of the deburred edge?
Any thoughts?
Thanks
rummels
Any thoughts?
Thanks
rummels
