- Apr 3, 2011
Or just buy another grooved wheel and run them on the platen and a smooth idler on the third wheel adapter. Adding another smooth wheel will only make it tighter. You’re running on the outside diameter of the rubber wheels, which is wider than if you were running grooved wheels.
You might be trying to do to many things with one tool arm.
I went ahead and ordered another grooved wheel so I can do as you suggest, but I also ordered a 33" belt instead of the 32" I was working with. Should make it much easier with the 3rd wheel attachment slots, I can put the belt on then slide and tighten screws and be good to go hopefully.
