i ll be that guy. stop with the "shaving sharp" you really dont know what that is till you hone a straight razor properly. most makers call shaving sharp scraping hair off your arm or leg. a razor that is properly honed will cut hairs without touching the skin (tree topping sharp) ok rant over
keep it simple most of my kitchen knives get sharpened to 1200 grit DMT hone in house the edge i send them out with is 3 micron film belt run slow and wet with a strop on a bench to finish thats for XHP at 62-63 Rc single bevel kitchen knives and straight razors are the only blades that get the water stone treatment and most the time i stop in the 8K 12K grit range depending on blade
I stop at 1000 grit waterstone
I think guys can overthink sharpening
Having said that I really want a Belgian coticule that's supposed to leave a unique toothy edge that lasts and lasts
Very true. I still haven't got my razor as sharp as it should be. With some knives I will take them to scraping facial hair but I would never want to shave with one. I have tried a patch and it's not nice.i ll be that guy. stop with the "shaving sharp" you really dont know what that is till you hone a straight razor properly. most makers call shaving sharp scraping hair off your arm or leg. a razor that is properly honed will cut hairs without touching the skin (tree topping sharp) ok rant over
I've never heard of that. Just looked it and appeared to look like a regular stone. What's different about them from a Japanese stone?
A coticule has regular grit sized particles then about 30% garnetsI've never heard of that. Just looked it and appeared to look like a regular stone. What's different about them from a Japanese stone?
Belgian coticules are natural whetstones. I think they are most well-known to straight razor sharpening enthusiasts. I think people feel they can give similar edges that Japanese natural stones do. From what I understand, the variety of sizes of particles in these natural stones can also give a high polish with toothiness as well as various nice cosmetic finishes. Everything is just a tool though, depends on what you're looking to accomplish.
Just to put this out there. I am going to guess that the fine edge is not what is doing your cutting but rather its is the fine apex. If you are using simple steels regularly in the kitchen your knife may be sharp but its will not have anything close to a razor edge on it. There is cutting board of course but a single cut of a high acid food such as citrus or tomatoes with strip of the super aggressive "razor " edge and you are left with a "working " edge.Very extensive tests in the German kochmalscharf forum have shown that the following factors together will lead to the longest lasting edge:
- A guided sharpening system with pressure control. On the very fine stones (beginning with 12K) the blade should hardly touch the stone (a few grams), otherwise the very fine edge will be damaged.
- An inclusive angle of 36 degrees. This is a good compromise, lower lasts shorter, higher cuts worse.
- Finishing on a very fine stone (Shapton 30K or Gokumyo 20K) and then a natural stone.
I sharpened a kitchen knife made of 1.3505 (comparable to 52100) this way and the knife was easily slicing ripe tomatoes after more than 6 months with daily usage.
Of course, this can be considered overkill and it's not necessary in any way but these findings were crosschecked by many in the forum.
If you think about it, it makes sense. A highly polished edge is normally very short lasting because it gets damaged while sharpening by hand or without pressure control. The very fine tip of the edge is very thin and the normal pressure of the blade on the stone easily causes micro damage.
Something I don't see discussed (ever) is asymmetry. I use my knives for wood, so my use is a little different, but I sharpen them a little like they're chisels. I hollow and polish the back (EDIT: back = the side in contact with the work surface), and then sharpen from only one side, but with a coarser grit. I have found that asymmetric sharpening provides a wonderful balance of properties.
This is very important to me because I like whittling aggressively hard woods like african blackwood, which murders edges. I rough with custom knives because they last orders of magnitude longer than the expensive hand tools, which I can then save for when they're needed. Cutting with the polished side down leaves a very nicely finished surface, almost as good as full polished, but it will last a good bit longer, and is much easier to revive with a strop. I believe that the steel has a lot to do with how long this lasts, but geometry is more important, and within a single steel type and heat treat, a shocking variety of results are possible. For wood, I mirror polish the back (to 1200 on diamond lapping plates, then 1k, 2k, 5k stones and a strop), but only take the edge somewhere between 400 and 1200. Coarser lasts a little longer, but starts leaving a finish that I wouldn't quite call polished. I like to go as polished as the steel will allow, but this is case by case. I find 1200 to be the upper limit of useful for even fine grained steels, but for something like k390, there's no reason to go over ~600. Realistically, 1200 on V4e is really just because I like the finish from the stone. 800 would probably be a better target, but I don't have an 800 grit stone. I also never leave a diamond finish. Diamonds set bevels, but waterstones finish edges. Convexing the coarse side also has a noticeable positive effect. The angles and grits I use reflect the steels I like (Vanadis 4e, cpm 4v, and k390), so
While my criterion for sharp is leaving a polished cut and yours is shaving, my sharpening technique (one polished flat, one coarser convex side) has made a bigger difference to my use than any other single factor. There's a bigger difference between the same k390 with good vs bad geometry than between k390 and 1095 with the same, excellent geometry.
The last thing I can add is that every knife is different. There are just too many microscopic variables, even between 2 identical models from the same company. The best protocol I have found is to set up your edge the way you like it (for me, as above) and use it as you plan to, but a little worse, and see how it fails. Shaving sharp is easier with a razor because the geometry is purpose designed for it. I don't test woodworking edges by shaving (at least not for any compelling, empirical reason). I have a piece of african blackwood that is loaded with unpredictable ultra hard inclusions and is the current champion for the hardest on edges of any piece of wood I have ever seen. I sharpen a knife, press it into the side to see how far it will go (this tells me the bulk geometry is good), then take a few torquing cuts into the figure in a few different spots and examine the edge. If there is any damage, the apex was too acute and I'll go a little steeper on the convex side and try again. The best edge for your use is always going to be the one you find empirically like this.
Sure, $250 per hour including sample prep is the cost for SEM pictures at the Metallurgical lab by me. My wallet seems to be a little too light for that on a knife maker salaryHas anyone ever obtained SEM (scanning electron micrograph) images of different edges? “A picture is worth a thousand words” ... might be helpful here...
https://scienceofsharp.wordpress.com/this may have been discussed on the forum before ... but with a quick search and interesting discussion, with pictures, came up. It can be had HERE ... (if the link does not work, here is the address.. https://www.razoredgeknives.com/2014/12/05/coarse-apexed-vs-fine-apexed-edge/ ). Interesting photos of edge and bevel geometry versus grit ... and also some discussion of trade-offs between edge and usage ...)
Hmmm. No promises ... but if i were able to lay my hands on some small (1” square or so) samples sharpened to varying degrees, i might well be able to get some images....Sure, $250 per hour including sample prep is the cost for SEM pictures at the Metallurgical lab by me. My wallet seems to be a little too light for that on a knife maker salary
