I have been using a diamond paste on basswood strop quite a bit. It turns grey with metal fairly quickly as I play knife. I've been cleaning it with WD40 as recommended here.
Do you add more paste after cleaning?
I have been using denim with mother's mag with great success and through it out when glazed/black
i have one question hear please,about using denim and mother's mag-polish! i have these things laying around my house but never thought of using them for stropping,do you just use a strip of denim with no backing or wood!using the mother's mag seems strait forward though,i have always used regular leather on pine wood with compound or basswood/diamond paste for my stropping needs,i stumbled on this post and had to ask the dumb question!forgive me,thanks.![]()
One thing worth mentioning is that the denim works very well to remove the burr. A handful of strokes per side and your good to go.
WD40 takes about 4 seconds to clean my leather blocks to like new condition. Nothing is better periodNo real set time... just:
- Determine what change (hopefully improvement) you get from stropping
- Recharge the strop when you no longer see this change
- Clean and recharge, when recharging alone doesn't improve the result.
Sounds overly simple, but results is the best way to determine this. Just turning gray doesn't matter... that happens fairly quickly. If you clean a strop, then you need to recharge it. (And basswood could probably just be wiped off... no real need for WD40).
