- Apr 5, 2003
I've bought a lot of custom scales over the years, and found from the beginning that they would affect the operation of the knife, almost always for the better. It took me a while to get a clue as to why, but I think it boils down to screw hole placement and counterbore flatness.
Recently for the first time I got a set of scales that makes a knife work incorrectly, every single time. I've done four re-assemblies on 2 different copies of the knife, and they cause the detent ball to totally miss the detent hole, and also too-early lockup that lets the lock be defeated with blade pressure. Fortunately both knives went back to normal after putting the original scales back on.
Has anyone else had good/bad experiences with scales affecting their folder?
- If the screws heads fit snugly in the counterbores of the scale, but the hole placement isn't precise, then tightening the screws will cause torsion to the frame.
- If the counterbore isn't flat (i.e., not sufficiently perpendicular to the standoff or pivot that the screw is going into) then the screw head isn't bearing equal pressure all the way around, which causes a lateral force that shouldn't be there.
