How thick is 3/32 of an inch?
Is 3/32 thick stock suitable for a knife blade? I have a terrible frame of mind for numbers and I was planning on making a custom knife for my buddies birthday. Is it thick enough? Will it have any serious flex or is it thick enough to stay rigid.
Slightly thicker than 1/4 of an inch I suppose, unless someone corrects me
Since 4/32s is half of 1/4 (i.e., 1/8), you couldn't be much more wrong.
3/32 is slightly less than a 1/10th of an inch. It is about what you would find in a kitchen knife.
4/32 " is 1/8" so 3/32" would be a bit thinner though would make a decent blade for light duty.
3/32 is 50% thicker than 1/16.
3/32 is 0.094, which is a hair thicker than 2mm.
My Svord peasant knife is 2mm thick and 3-1/8" long. My Mora 511 is 3/32" thick and 3-3/4" long. Not much flex in either of them, and I consider them strong blades. They are thin by American standards, because things need to be bigger, thicker, heavier in the USA.
Maybe a 4 inch blade. I decided and finally bought 1/8th instead of the 3/32 thick stock.
I think you couldn't go wrong either way for a 4" blade. Some folks take Old Hickory kitchen knives and modify them into 4-5" bushcraft blades. The Old Hicks are around 3/32" thick.
Just for reference, here is a spine shot of a knife I own (a Backwoods by Bill Akers) that has a 3/32" thick blade. Blade length is 3 1/2 inches.
A sixteenth and a half, as Dogstar said. That's a good way to visualize it.
A thirtysecond is easy to remember if you are mentally going decimal as it is (about) 30 thousandths of an inch. (.031")
1/8" is a pretty thick blade to me.
My Moras are 2mm thick, 3/32" is 2.3mm, so if the steel is treated properly it will be more than thick enough for a decent utility blade.
