How to advice variable speed 1x30 sander
I was using my Ken Onion worksharp with the blade grinding attachment on it just the other day, and I really liked how I could bring the edge in on the blades I was working on with it. This got me to thinking, I would really like a decent quality 1x30 belt sander with variable speed. What would you fine folks do to try to achieve this.
Thanks for any ideas/advice--Don
Don, I'm not sure a 1x30 would be the best option for a sharpening machine. All the 1x30s I'm aware of, are fitted with a single phase motor. For variable speed you need a 3 phase motor with a variable frequency drive, or a small brushed motor that you could run through a speed control like you see on a Dremel tool or small router. Converting a 1x30 to a 3 phase motor might be difficult to engineer, or in the case of a brushed speed control,it would be under powered.
If I was doing it, I'd probably get a Coote 2x48 or a 2x72 frame and use a 1hp 3ph motor and run it through a KBAC-24D drive, but you would be looking at somewhere in the range of $850 or more to set this up. Here's a video of a guy using a 2x72 Coote with a VFD:
[video=youtube;XSF3VF9aIp0]https://www.youtube.com/watch?v=XSF3VF9aIp0[/video]
IF the sander uses a small motor without a starting capacitor, I believe you can use a simple rheostat-type speed control.
I have been meaning to check this out.
Does anyone have input?
I had read recently that even dry hand sharpening does microdamage to the temper of the edge. How can a belt sander not be heating up the edge itself in an uncontrolled manner?
When sharpening or anytime I'm grinding post heat treat I run slow and wet to keep the blade cool.
I've been looking around for a belt sander as well and found a couple of variable speed bench grinders with 2x36/2x48/4x48 belt sander attachments that can be fitted.
Any recommendations against this relatively low priced option?
Those variable speed grinders go from real fast to haul ass.
They don't run slow enough to do what you want. I have a couple of them.
That's what I was thinking after reading the RPM specs. That and they seem to be underpowered.
Back to the drawing board.
Would it be possible to run a bench grinder with a pulley to a large diameter wheel mounted to the belt drive axle?
I don't know what hp motor would be required since I am sure the torque would drop off significantly.
Bench grinder > pulley > belt > bicycle rim* > drive axle > belt drive wheel > belt grinder?
*bicycle rim suggested since that was the lightest large diameter wheel I could think of, thus robbing less torque to get moving. Though a light wheel would maintain less momentum once up to speed.
I doubt this would work, but does it get anyone thinking laterally?
Did you read that on-line ?
Hmmm.
Rubbing your fingers over a blade removes microscopic bits of the blade too.
Realise internet is like public toilet stall of information.
Fwiw, beltgrinders can overheat a workpiece. Right quickly too.
An operator understanding the overall grinding process can prevent damages.
Yes, I did. Here:
http://www.hypefreeblades.com/forum/viewtopic.php?f=3&t=682
Roman Landes is a materials scientist and knife maker with access to an extensive laboratory. Apparently he just proved something that was already known in some circles. It's an interesting read.
There are Chinese 1 X 30 variable speed vertical/horizontal grinders available on Ebay. They cost about $300.
I would buy one if I had room for it.
Look up curry custom cutlery on YouTube he has multiple videos about how he modifies his 1x30
