Hi guys. Rookie knife maker here, go easy on me.
I'm making scales for a Damascus blade I bought.
I'm making it of micarta, I'm totally down with the epoxy/fabric part of it, I worked with glasfiber and epoxy for years.
Original I wanted to attach the blade with brass pins, but have since decided to go for screws, cuz I think it looks better, the kind of screw with a barrel in the middle with inside threads, and a screw on each side through the handle.
When the plan was to use brass pins, it was fairly straight forward.
-Cut the micarta to roughly the correct size
-Mount with epoxy or glue together with brass pins
-Sand/file/cut micarta and brass down to desired shape and size
-Go have a cold bear.
But now I'm not quit sure how to do it, I obviously don't want to sand my screws down, but I can't really see how I can shape the handle without attaching it to the blade (I want a perfect fit/level between the steel and handle material)
....do I attach it with brass rods, and then after I'm done shaping, knock out the brass so I can countersink the holes and put in the barrel and screws?
