Here you go:
Knife Type - Santoku
Blade Material – Hitachi Blue #2 steel
Handle Material - Snakeskin Sycamore
Made in 2017, by Stacy E. Apelt – Bladesmith
Simple and Clear Warranty:
You do your part - Hand wash after use and dry. Do not put in dishwasher. Use for cutting vegetables, meats, and fish.
Don’t use as a pry bar or screwdriver.
Treated right it should last for decades.
The blade is high carbon steel and will rust if left wet or exposed to food acids and not cleaned. After washing, dry well and place in a safe place where it will not get wet or splashed on. A light oiling with vegetable oil will aid in keeping the blade rust free. If any light rust or spots form on the blade, it can be removed with a Scotch-Brite pad or 4/0 steel wool. DO NOT sand blade with sandpaper to remove rust.
A natural darkening of the steel, called patina, will form on the blade over time. This is an oxide layer that protects the blade from rust and spotting. It can be hastened by rubbing mustard or lemon juice on the blade and letting it sit for half an hour. Repeat as needed to get a darkened blade. Wash off well and dry, then oil.
I’ll do my part –
If the blade dulls with use, I will re-sharpen it.
If the handle ever needs re-finishing due to wear, I will gladly sand and re-buff it.
If the edge gets nicked due to accident, I will restore the edge.
If the blade or handle breaks due to normal use, I will replace or repair the knife.
___________________________________________Date______________
