I've made western mounts. Boiling works, get as much flesh off as possible prior to boiling. The brains come out the base of the skull where the spine ends at the head. No, there is no access to the cranial cavity from the eye sockets or nasal passageway. Your reply certainly tells me that you have never undertaken such a task. If the skull is not fresh, be prepared for some gruesome odors. Cooking will certainly intensify these odors. Your neighbors will hate you, don't tell anyone what you are doing, it's better if they don't know who to blame. A mild bleach solution will help whiten the bones. Overcooking will make the teeth come loose and also will remove the cartilage. The bent coathanger will help fragment the brain tissue, but, again be forewarned of the foul odor. I don't know why, but cooking up a skull will in no way smell like dinner. The bug method is absolutely the best no-work method. But, all the while the bugs are munching, there is the awful stench of death to contend with. The bug method is only feasible if you don't have neighbors. The bird method is ok, but, it will take a year or more ,the skull will be weathered and gray and you will still end up with even worse hand labor to clean 'cause now the gore will be dried on and you will need vise-grips to try and pull it off. Good luck, I can think of lots of better hobbies, are you related to Jeffery Dahmer?
