You can skip the step of removing the stop pin. The two halves will come apart without loosening it. Assembly would then be started on the lock bar scale rather than on the presentation scale.
Also, I lube the pivot hole.
anyone else have this "issue"?My stop pin does not budge when you take the inkosi apart.
Yes cannot remove the stop pin from the slab. And yes I remove the screw.Do you mean that you cannot remove the slab from the stop pin? Do you have to remove the screw holding the stop pin in place?
Thanks bhyde! That's good to know.DON'T remove the stop pin- There is some alignment/clocking on it and it's not fun getting it back into place.
There isn't a reason to totally remove it anyway that I can think of.
