How To Finsih Resin Handle
Hello Everybody,
I’ve been stalking this forum for a few months now and have learned a lot. Finally decided to join. So I have searched the web and this forum and can’t find a good answer to my question. I bought some knife scales off eBay for a knife I’m working on for my wife. The handles are made of what appear to be solid resin. My question is what is the best way to finish this. I tried sanding on a test piece but it was full of scratches. I only went as high as 400 on these piece but will go higher once I a full put the knife together. Should I just keep sanding to a higher grit and buff it? Is there something to seal it with to hide the scratches? I appreciate any advice and also appreciate how much y’all have helped me without y’all knowing. Here’s a link to the scales if it will help.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/173210377065
I appreciate the reply. I figured so just didn’t want to put in all that work if there was a better way. Do you recommend wet sanding a certain grit? Also what about polishing compound? Any certain brand? Haven’t really polished much before. Thanks again.
After sanding to 400 grit, use 0000 steel wool and buff in the opposite direction that you sanded. Then you need to buff the plastic with fine polishing compound shoe-shine style with a cloth.
I am a couple months late, hope this still helps.
I have only done one resin handle, but liked it. It seemed forgiving. I would sand for a bit, then before going to the next higher grit, i hit it with the buffer real quick to make sure I liked the shape and I wasn't missing anybig scratches. Not sure if that is the right thing to do. But worked for me
