- Dec 27, 2013
Hey guys. Ive got a bit of a lull in classes before finals, so I thought I would write a small article about something other than wood. Etching.
Knife makers love etches, they let us show off hamons, damascus, darken steel and even clean some steel if you are tricky "Send me a message if you are interested in this"
I want to explain some things about etches and acids. This is going to assume little to no prior knowledge of chemistry, so please dont be offended.
What is an acid? Simply put an acid is a chemical, compound or solution that can donate a Hydrogen ion. .
So what is a hydrogen ion? Its H+ or a single proton. Atoms are made up of protons neutrons and electrons. Hydrogen in normally one proton and one electron. Take away that electron and you have H+, the essence of an acid. You have probably heard the term pH, which refers to the power of the hydrogen. It can be understood as the concentration of H+ ions in a solution. Any number below 7 is an acid, and each number down is 10 times more concentrated.
So, why are acids important to bladesmiths? Because metals are proton receptors. When a metal like Iron is in contact with an acid, atoms of iron become ions, generally Fe(ll) which will dissolve in water. That means you can dissolve metal and any contaminants with an acid.
The more important part is that different alloys and crystal structures react to acids differently. In a knife with a hamon, the edge is hardened ceminite, while the spine is ferrite, which are two different compounds that react differently to an acid. In damascus steel, Nickle forms a protective oxide very quickly on contact with acid called a passivization layer. This prevents the nickle baring steel from being etched further. On the other hand, manganese reacts very strongly with acid, etching quickly and leaving a black oxide pattern. This is why high manganese steels like O2 make such vivid damascus.
Now that the background is out of the way, how can you take advantage of it?
The biggest issue I see is people making their etching solutions too concentrated. Ferric Chloride is a special kind of acid called a lewis acid, ill explain that later if people want. But understand that when you mix ferric chloride with water, you make an acidic solution. But, remember how the metal is being dissolved. The metal reacts with the acid to form an ion that becomes dissolved in the water. The water dissolves. Not the acid. When someone's etch is dead, most of the time the acid is still strong enough to etch, but the water is saturated. Nothing new can dissolve in it and thus it stops etching. A rule of chemistry is that dilute acids are more efficient. You may have heard this as a long slow etch gives better results. This is because that long slow etch has lots of water free to dissolve more material.
Think of an acid like a drill bit. The H+ is the acid part that everyone cares about. That is steel. But the water is the flutes. With no flutes, you cant remove any material. A super concentrated acid is one with very small flutes. Yes it can start to cut anything, but you simply cant remove the material.
I think this is partially responsible for the popularity of the coffee etch. Its such a dilute acid it has a fantastic efficacy and can thus slowly etch surfaces evenly.
So, how can you get a better etch?
Use a dilute acid. Dilute acids are always more efficient.
Warm your solution. A warm solution not only lets the acid work faster, but a warm solution can dissolve more material and is thus more efficient.
Use distilled water when making an etching solution. The Chloramines, florides and other trace elements in water mean it has a lower capacity. Granted its not much, but it is something.
I've got to go to class, ill try to write more about my special etches and how to use acids for prepping stock for damascus soon.
