They r full tang actually which is pretty cool to know, the only problem I think is that the scales when fit (like u said) would be really hard to get a good fit seeing as the tang is shaped weirdly (it has bent protrusions on it ) a handle made of anything other than paracord without drilling would be toughAnything is possible, but its worth considering that part of why Mora gets away with partial tangs is the injection over-molded handle does provide some of the overall stability. Not sure how much of an Eldris handle has tang in it, but you'd be needing to get a very tight and well bonded fit. Certainly possible, but for how much effort?
Wow that’s crazy I didn’t know that, if I get one I’ll test it outI've seen some "hidden" tang knives where the maker did a cut-out on one scale, deeper than the tang, and then had the other scale key into the other side of that cutout, so in essence the scales were offset. The one I saw was done with blind pins in micarta, so it looked like it was one piece. Could also be done with wood. Epoxy can do some amazing things.
Really nice work. To be clear, are those 2 pins placed strategically to fit into the cutouts in the tang? Are those solid blocks of micarta that have been drilled out for the tang?
It’s a sandwich…First it’s a 2mm brass plate with a cutout of the tang in it. Then there are micarta/G-10 as scales. And yes, the pins are kind of strategically placed to fit the cutouts in the tang and go all the way thru. I’ll post a pic of how it’s done…Really nice work. To be clear, are those 2 pins placed strategically to fit into the cutouts in the tang? Are those solid blocks of micarta that have been drilled out for the tang?
