I have a Bradley Kimura balisong and I used some blue Loctite on one of the pivot screws it has. I can't unscrew it at all now. The pin that the screw is screwed into is rotating with it, and it is flush-mounted into the handle so I can't use a pair of pliers to immobilize it as I try to unscrew it out. I tried soaking it in hot water, using a hairdryer, heating up the torx driver and using it, the pin and screw are simply refusing to separate. I would appreciate some help, thanks.
