I purchased a Vietnam era silnylon poncho- took me quite awhile to find one of the lightweight silnylon ones vs the heavier rubberized ones (little factoid- in 1968 the lightweight version replaced the rubber one as it was deemed too heavy and too shiny)
when I got it, it was covered w/ a lot of white power for storage, wiped this off w/ a damp cloth to discover that a lot of the sealant around the hood area was peeling- which considering this piece is ~ 40 years probably not unusual
I thought about sending it back, but then I found this article on treating silnylon
http://jwbasecamp.com/Articles/Silnylon1/index.html
and although it talks about treating tent floors, it would apply to any silnylon product
I went to Walmart and spent $5 on a tube of clear silicone sealant and a small bottle of low odor mineral spirits and a couple of cheap foam brushes
as per the instructions I mixed the silicone to mineral spirits 1 part to 3 parts, takes 3-5 minutes of mixing to get it sufficiently diluted, then apply
make sure you have adequate ventilation
I let it cure overnight and then turned it inside out and treated the inside- for the inside I used a more diluted solution- 1:6, this is probably closer to what you'd want to revive a modern silnylon tarp/poncho (I've even read up to 1:10)
in case you think this only applies to 40 year old pieces of kit, there have been several articles recently about the degradation of the hydrostatic head of silnylon
http://www.backpacker.com/cgi-bin/forums/ikonboard.cgi?act=ST;f=832107219;t=9991147454
fortunately the "fix" is cheap and easy
