How to sharpen a machete
Unauthorized advertising
Hi all,
You all know that a machete is a very versatile tool. It's a tricky part when it comes to sharpening it as no tools are more trickier than that. In this post, I'll cover this topic.
There are many unique tools out there that can be used for machete sharpening. In this article, we will talk about how to sharpen a machete with:
1. Belt sander
2. Grinder
3. File
4. Dremel
5. Whetstone/rock
01.Sharpening a Machete With a Belt Sander
Belt sanders are the most common and easiest method of sharpening a machete. Through this wonderful tool, you can easily give your blade a go that will result in a sharpened machete. A convex utility edge can easily be given if proper techniques are maintained all through the sharpening stage.
You just need to give a light pressure and a straight edge is there for you! Just don’t overheat your machete when you are running the blade across the belt. That will harm its carbon-steel composition. Besides, it’s much easier than using a grinding wheel for your machete. A moderately priced belt sander will be enough for your machetes.
02.Sharpening a Machete With a Grinder
Grinding wheels are mostly used when aggressive sharpening is needed. This process helps to eliminate the factory dullness or big nicks. As you need to sharpen your machete with a grinder in one go, the work area needs to be spacious enough for you. That will help you to get an even edge.
Also, the grinders can make your blade really hot if it is operated at a higher rpm. So either you need to operate it at a lower rpm or you need to continuously pour some water on the contacting parts of the tools. Otherwise, it will turn your blade composition into a lower grade. Both of the processes are considerably difficult if you are not experienced enough. That is why this technique is not a favourite among machete users.
03.Sharpening a Machete With a File
For a simple sharpening process, you can seek out help from a file. It doesn’t require much technique to get a sharpened blade. Firstly, you need two things for sharpening your machetes, a vice to hold your machete tightly and a file. There are mainly two types of file, one is a double cut or rough and the other is a single cut or smooth. What would be the best is a bastard cut which is an intermediary option of the two.
Once the machete is tightly held in the vice at the desired angle, you need to push the file repeatedly over the blade. Remember that you can’t pull it rather need to push it. Also in a reverse way, the machete can be drawn against the file. Once one side is done sharpening, the whole process is repeated on the other side. As files are really small to carry with you in the woods, you can also regain the sharpness of your blade there!
04.Sharpening a Machete With a Dremel
This sharpening process is also very common and easy to undergo. A Dremel is some power tool which is operated handheld having a rotating sharpener at the end part of its shaft. You also need a vice to grip the machete. Then you need to power up the Dremel and run it over the edge of the tool laterally. Once one side is done, you need to repeat it on the other side.
As the sharpening is done by lateral movement of the sharpener, there is a huge chance that the edges can become uneven. The reason is that you are not sharpening the whole edge in one go. But for small imperfections, this is a very good way to rectify that. That is why this process is most suitable when you are giving your machete a slight touch after some heavy uses in the fields.
05.Sharpening a Machete With a Whetstone/rock
This is another traditional way of sharpening your machetes to give a polished edge. For this method to work perfectly, you need a whetstone/rock, some water and a beacon if you are using an artificial stone. Firstly, soak the whetstone into the water for some time. Then you need to move the blade perpendicularly at an angle from the base of the stone to the tip. You need to move the blade up and down the stone for some time.
This process doesn’t require a lot of techniques and is a simple way to get your blade sharper within some minutes. There are many whetstones out on the market that can be handy. We have an article on the best sharpeners where we have talked elaborately on that. As this process doesn’t require so many tools and techniques, it’s a popular method among the users.
Machete Sharpening Angle
When you are going to sharpen your machete, you need to select the angle very wisely. Because machete sharpening angle directly influences its fields of performance. If the machete is used for cutting grass and non-woody staffs, then small sharpening angle is very suitable for that. An angle of 20-25 degrees would be really suitable for that purpose.
And if you need to cut wood branches and thick staffs then a larger angle of 25-35 degrees is recommended for a better output. In that case, the machete can take the beating of repeated chopping. Also, in case of a smaller angle, you may face problem for having a fine edge as they may get chipped away. So much concentration is needed for your blade sharpening angle.
Hi all,
Y(I've also elaborately described that with videos on my website: <deleted>.com, so you also can check that out!!!):
So I see you and your site that you are promoting are an Amazon associate, and get paid for each time someone clicks through on your site to Amazon.
Would that be correct to say? Your site you have promoted here is a money making venture?
Also, we do have an entire subforum devoted to Maintenance, Tinkering, and Embellishment, i.e., sharpening.
I just use a Nicholson single cut mill bastard file, and the coarse stone that came with my machetes.
I'm always swinging in or around the ground hitting rocks, so I've got no need for a razor edge.
I keep them kind of blunt actually, a more durable edge thats just sharp enough to get through weeds...ect without a struggle.
These are all informative article that I've shared !!! And amazon doesn't give you money just for clicking!!
I got one of those "TORMEK" wet grinders some time back and I mostly use it to sharpen my two machetes and my two Gurkha Kukri Cold Steel models. I also use it to sharpen ax bits and hatchets/hawks. But I do find this thread interesting because I'm a firm believer in learning to do certain jobs manually. I actually find freehand sharpening with benchstones/whetstones to not only be challenging but relaxing as well.
Don't own a belt sander but I have been looking seriously at eventually getting one. But I have also found that diamond benchstones ( especially coarse & extra-coarse) are great for setting up the right angle for finishing. I like this thread because sharpening machetes and axes are a job that many people think is super simple but that's not the truth because it takes skill to sharpen those as well as it does knives.
Even after I use the TORMEK I sometimes will get fine benchstones to do a final finishing job with. Again a very interesting thread and I hope that many more chime in.
I find coarse silicon carbide or aluminum oxide stones to be more rapid at hogging off metal than diamond plates, as you're able to use greater pressure.
An example of what sufficiently coarse silicon carbide can do:
That is helpful. Glad to know that man!
That is a wise way to treat your blade!!
I plan to get one of those files. I have a cheaper one I, maybe a lansky, that I half wore out thinning out a massive kukri blem to make it a better chopper instead of a splitter. I was impressed how these work and they get into the curves very nicely. Works nice on chipped axes too if I get a little crazy with the fiskars.
For machetes, I like sand paper on a sanding block. I think there is a youtube that calls it the rooster method but I've found it works nicely for axes and machetes, especially thicker machetes like goloks.
This is my solution for sharpening long blades and serrated blades.
The pivot point is 3D and can be moved forwrad and back, up and down, and sideways.
Machetes can be sharpened, also when the bellly and tip are as in this picture.
This tool can sharpen very small blades up to swords - with wanted type of edge, flat or convex.
Both flat and convex edge can be sharpened in wanted edge angle and xonvex edge can be sharpener with wanted convex sphere in degrees - and the edge can be maintained in the same angles.
There is a built in protractor on this tool - and files can be used with this tool with a fileholder as extra attatchment.
Machetes can be sharpened in many ways, this is one of those ways.
Thomas
I end up giving my machetes a 5 degree primary bevel down to about 0.015" then sharpen down to 12 to 17 degrees per side on my Norton Economy stone. I used to use a belt sander, but actively discourage them now after many heat related issues.
Thomas
Thanks for sharing!!
Hey guys and I don't mean to detract from the subject matter>> but what sharpening tools do any of you use for field use for sharpening machetes? Right now I have a couple of round puck type stones and one rather big round stone that I've been using for field use in sharpening machetes and other big blades. I kind of wonder what sharpening tools you all use for field use sharpening of big blades?
I've also wondered if any of the diamond sharpening tools makers like DMT have anything for field use for machetes and other big blades? I got both my round and puck type stones from a company in Texas called "Sticks & Stones">> they have a huge selection of sharpening stones.
I have a small puck and a 6" mill file. I also bring a chunk of compound and just smear it on smooth bark or wood and strop on that. If near my house or car, or carrying a pack, I use a Washboard block w/ compound.
DMT should make a puck.
