As a fairly new knife maker, yesterday I showed a chef my first chef's knife. He suggested I taper the blade, and afterwards I realized I don't know the best way to go about that. I first thought about tapering the blade before grinding the bevels. In grinding my bevels, I use a jig through about 120 grit, but if the blade were tapered, it wouldn't sit flat on my jig (without spacers or something else). I then wondered if I should just grind my bevels as normal, and then taper the blade. Basically I don't know what order to do things. I was thinking of doing it by hand, but I do have a surface grinder with adjustable angles, so I could probably taper a blade on it, using spacers for one side. Obviously I don't know where to start, and any suggestions would be appreciated.
