I'm curious about this with a bushing construction like he said. Assuming the bushing is the right size wider than the blade, wouldnt "overhammering" be effectively impossible? Once the bushing is seated/locked against the liners square, even if you were to completely deform the pin within that bushing, the blade simply rotates around the OD of that bushing regardless, no? The bushing really can't keep any orientation but square to the tang.
Perhaps with crazy smashing you can deform the liners themselves in some way that causes the blade to get pinched?
I only ask because since I went to bushings, I really hammer the F out of pivot pins if they are using bolsters and I've never had one bind. I even put the pins in my milling machine vice and "press" them with such force that they create an actual, flat rivet.
