Comparing 8cr13mov to s30-110v isn't apples to apples either, totally different level steel...
Generally speaking, 8cr means your looking at "affordable" range knives, and truthfully, I wouldn't "recommend" battoning or prying with any lower grade stainless knife persay, something like154cm, or 3v would be much better suited in a stainless blade, or even 440c; as mentioned above by someone even aus8 might be slightly better for that purpose (or even a 440, aus6 or 420 or 3-5cr13), because its slightly softer properties.
Now I'm no metallurgist, But I do know for daily light duties around the house, It will surely do the job as would most any half decent knife steel, depending on your definition of "light". If your going to clear briars and weeds from an existing game trail, pry some weeds out of the dirt in your garden, and hack down some low hanging (small) branches around the house, an inch or so thick, the it wouldn't be an issue for most any reputable sourced steel including 8cr.
If your idea of "light" includes prying cement pavers up up from the walkway and clearing your own trails from scratch, bushwhacking through 3" saplings, and it breaks, warps, chips, etc. then you should've sprung for a more tried and trusted bushwhacking blade.
