Okay just so I'm getting this right, the HRC of a blade is the rating of the blades hardness. The harder the blade the longer it will hold an edge, but is more prone to chipping and damage because it is more brittle. The lower the HRC, the softer the blade, but the more durable the blade becomes. At a softer HRC the blade can then handle more impact and punishment.
To an extent this is true, the chemical composition comes into play as well. There are some that use N690 at HRC of 60 and AEB-L at 62 in choppers with little to no issues and those are considered to be brittle HRC readings. Same with simple carbon steels such as CPM-3V, O-1, 1075, however, they are heat treated appropriately (therefore onto your next question)
Question time:
I see different makers using different techniques to construct there blades and different heat treat methods to achieve their desired HRC rating. Do these different techniques and methods make these blades perform any better than the others if they tested at the same HRC?
Example:
Knife maker "A" uses a brute de forge technique to construct his blades and uses the most basic heat treat method to achieve HRC 59 on his 01 blade.
Knife maker "B" machines his blades and heat treats with Cryo to achieve HRC 59 on his 01 blade.
Knife makers A and B's blades are made to the exact same specs, the finish products are identical. Will one perform any better?
Yes, the procedure done during heat treatment is very important.
The advancements of cryogenic treatment of steel when done right has been known for some time to improve steels wear resistance and hardness. A bit of googling can find some papers:
Comparison of Cryo on different steels
metals-cryogenic-quenching-of-steel-revisited
key_engineering_materials CRYO treatment on 3 tool steels
There are many other aspects in the heat treat process that can contribute to how a steel will perform for the end line user. Holding time, time between austenisation and tempering, method of quench, quenching medium, maybe even secondary hardening to name but a few. This is why a maker spends time talking to the maker of the steel, Bohler, Crucible, Erasteel, Damasteel and follow their recommendations, they have the metallurgists in house. Some makers claim "secret" heat treat with an obscure amount of tempers, secret heat treating ovens etc, IMO things like that, unless proven with scientific metallurgical tests are false, there is a reason why there is recommended hardening and tempering program with steels from a company.
Some steels do not even like deep cryo treatment. H13 in one of the above studies did not give any respond to cryo treatment.
Not only that, but HRC measurements can be severely flawed if not calibrated, monitored and kept in spec. There was quite a big discussion on HRC measurements on the Spyderco forum and why Spyderco do not publish their HRC data. Simple conclusion is that too many people get focused on those numbers without taking into account other aspects such as the process followed during heat treat.
Here is a good book about heat treating:
Thank you to John D. Verhoeven for making this book available to the public.
Metallurgy of Steel for Bladesmiths & Others who Heat Treat and Forge Steel - By John D. Verhoeven (2005)
Here was a good read from Kevin R. Cashen (American Bladesmith Society Board Member and has done a lot of work regarding analysing steels under the microscope) regarding some Cryo treatment.
"The skinny is that conversion of retained austenite is the one absolutely proven and uncontroversial claim of the cryo folks, it just works. However... if you have enough retained austenite to notice a difference in 10XX, W's, O-1, L6, 52100, 5160 or the other low alloy steels the better solution is to fix your initial heat treatment (overheating before the quench being the most likely culprit). With these simple steels, any treatment to deal with R.A. after the hardening operation is simply putting a band-aide on the symptom without addressing the real problem, whether folks like it or not the old harsh saying is true, that it is just propping up a poor heat treatment. This is aside from all the other quirky or theoretical claims of cryo and just dealing with retained austenite. If a person is gaining 2 points HRC in their 1095 from freezing, the are blowing it badly in the hardening operation, and need to deal with it, instead of announcing to the world how poor of a heat treater they are by extolling the virtues of keeping knives in the kitchen freezer."
