- Jul 20, 2011
Being european, I used to use metric sized screws for my folders but since there are a lot more different screws available in the imperial sizes, I recently made the switch to american screws, and purchased a load from USA Knifemaker. Furthermore, the 1-72 carbon steel taps where about 30% the price of the HSS M2 (2mm = .080 inch) and even the screws were much cheaper.
Today I was tapping .080 titanium for 1-72 screws, drilled with a 1,6mm drill, which is quite a bit bigger than the recommended #ed drill. I thougt I was quite carefull but I broke the carbon steel tap on the first hole. I felt quite a lot of resistance trying to cut the thread. I then decided to try the M2 HSS tap, which is about 11 % bigger than the 1-72, using the same 1,6mm drillbit for the holes. The M2 tap went through the holes like it was butter, and resistance felt much less.
I used a battery power drill and drove the tap through in one continious pass.
Both taps were tapered and seems to be of the same type, apart from the material.
My question therefore is:
Are Hss taps so much better than Carbon steel and are they worth the extra price (about 3 times as much)?
What kind of taps are the rest of you using?
Brian
Brian
