The caveat here is that 110V ovens are very limited in wattage. If you have a standard 15A circuit, you can only run around 1500 watts. The speed of the oven will be determined by wattage, chamber size and heat loss. You end up with manufacturers putting as much chamber as possible for a given wattage in 110V because we want to be able to heat treat knives.
Sugar Creek 110V ovens are considered "slow" because they run 13A elements in the absolute largest chamber size usable. The KM-14D has a smaller chamber but also only runs a 1200W element.
The speed advantage with 220V comes from the ability run more watts at fewer amps and run more amps over the wire. If you want 1500W out of 220, it's only going to cost you 6 or 7 amps but you can run up to 25 or 30A on most moderate 220 runs, thus allowing you many more watts per cubic inch, if the manufacturer takes advantage of them.
An oven heating fast doesn't necessarily mean it's doing a better job, so at the end of the day speed isn't really the biggest concern for me.
