- Nov 8, 2009
Is a 110v HT kiln or oven worthwhile? I do not have 220 in my shop, and do not want to add an electrician's bill to the price of an oven. Has anyone used a 110V unit and have any feedback as far as performance?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Electric ovens don't produce BTU's They produce watts Btu's are a measure used when you are burning something to make heatlike in a gas oven. Watts are a measure that is used when you are using an electrical resitance to create heat like in an electric oven...
You might want to re-think that statement. British Thermal Units -- units of heat -- are the end product of any oven, regardless of its fuel source. Burning one cubic foot of natural gas will yield 1030 BTU's. One kilowatt-hour of electricity will yield up to 3412 BTU's.
In North America, the term "BTU" is used to describe the heat value (energy content) of fuels, and also to describe the power of heating and cooling systems, such as furnaces, stoves, barbecue grills, and air conditioners. When used as a unit of power, BTU 'per hour' (BTU/h) is understood, though this is often abbreviated to just "BTU".
Ok so if Gary was talking btu's per hour then your point is correct. I was taught and use the north american formula but if you want to pick nits then you can use btu's if you want.
My point is that IT DON'T MATTER IF THE OVEN RUNS ON 110 OR 240 VOLTS THEY ARE RATED IN WATTS, SO IF BOTH OVENS ARE THE SAME OTHER THAN THE VOLTAGE. THEY WILL USE THE SAME AMOUNT OF ENERGY MAKE THE SAME AMOUNT OF HEAT AND HEAT IN THE SAME AMOUNT OF TIME.
So if you have 110/120 volts in your shop and don't want to / can't afford to put in a 220/240 volt leg then buy the 110/220 volt oven plug it in and use it and be secure in the fact that at the end of the month when you pay the electrical bill that you used/payed for the same amount of electricity and that you will never save enough money by using a 220 volt oven to pay for putting in that 220 volt service.
To the original poster, if you have no 220v in your shop, and no one you know is an electrician, then likely you would be best served with the 110v unit. If you lived in Louisiana, I'd come and run it for you in trade for knife work...
Well said. Having agreed with you there, 220v does make sense when using large motor driven equipment as you lower the amp draw, thus lowering the heating of your wiring and allowing you to run a smaller guage wire than the same load on a 110v circuit.
Dear Heaven
The oven will heat to the same temps as 220V - it will just get there slower and there is no harnm in that as long as you have the piece properely protected.
Rob!
No argument there. Sheesh, lighten up.My point is that IT DON'T MATTER IF THE OVEN RUNS ON 110 OR 240 VOLTS THEY ARE RATED IN WATTS, SO IF BOTH OVENS ARE THE SAME OTHER THAN THE VOLTAGE. THEY WILL USE THE SAME AMOUNT OF ENERGY MAKE THE SAME AMOUNT OF HEAT AND HEAT IN THE SAME AMOUNT OF TIME.
Rob, The highlighted text above is just not true UNLESS the 110 volt oven is rated at less wattage than the 220v oven. It is the heat generated in a resistance coil measured in watts that heats an oven. In all the comercially ovens that I know of the specifications given show the wattage ratings being the same between the 110 v and 220 volt oven of the same model . if the wattage is the same then the ovens will heat to the same temps at the same rates indifferent to the voltage they are running on.
