The Huawei CP60 wireless charger comes with a bunch of protective features, including temperature protection, short circuit protection, power protection, and over-voltage protection. Furthermore, there is a built-in protection for foreign objects. It is designed to offer wireless charging at a distance of up to 5mm, this means you can charge your smartphone without removing its case.
Product Features:
● 15W (Max) Quick Wireless Charge
Huawei's self-developed 15W (Max) quick wireless charge technology allows you to enjoy wired charging speed, wirelessly.
● Universal Compatibility
Qi standard, identifies smartphones, earbuds and other devices intelligently, and adjust its output automatically to charge them safety.
● Case Compatibility
No need to remove your phone case, conveniently charges through less than or equal to 5mm non-metal phone case directly.
● Foreign Object Detection
Automatically power off when detecting keys, coins and other metal objects, or control the temperature of ID/travel cards and other metal-containing items at a safe range to avoid overheating.
● Comprehensive Safety Protection
Built-in chip that can adjust the output power automatically according to the ambient temperature and real-time battery percentage.
● Silicon Surface
Soft and comfortable unibody silicon surface that both protects your phone and prevents it from falling.
● Light and Compact
14.4 mm high, ø84mm, 78g weight. Lightweight, slim and compact body that can be easily packed into the bag, allowing you to enjoy wireless charging anywhere, anytime.
Get Huawei CP60 wireless charger from GearVita, farewell to the limitation of traditional wired charging, and embrace the convenience and elegance of wireless charging: https://gearvita.com/huawei-cp60-wireless-charger-15w.html
You may also be interested in:
xiaomi huami amazfit bip smartwatch
redmi note 6 pro 64gb smartphone
Product Features:
● Silicon Surface
● Light and Compact
