Huawei WiFi 2 mini is 4G/LTE WiFi router, all you need to do is insert a SIM card, as it is unlocked and then the device is ready to use. The best feature about the E8372 is that it has a lightning fast download speed reaching up to 150Mbps and supports up to 16 terminals to connect simultaneously via WiFi. It does the same job as a hotspot, but is small enough to carry in your pocket.
Product Features:
● Built-in Huawei Hisilicom modem, supports LTE Cat4 with up to 150Mbps for downlink and 50Mbps for uplink.
● Connect with the laptop's USB port to transmit data and share LTE + WiFi with other devices at the same time, much easier and more convenient.
● Supports up to 16 devices to access simultaneously.
● Plug into car charger to provide a WiFi environment within vehicle.
● Huawei HiLink App makes device management more convenient by smart phone.
● 4G LTE FDD band 1/3/5/7/8/20/38 (800/850/900/1800/2100/2600MHz), TDD: B38/B40/B41
● 3G UMTS/DC-HSPA + 900/2100MHz
This Huawei WiFi 2 mini is not like any other dongle, usually you can only connect to one WiFi device with a USB port. Now, you can plug it in and use up to 16 devices of your choice instead of one, so it acts as a dongle and a mobile router: https://gearvita.com/huawei-e8372h-155-3g-4g-wifi-router.html
Guess you like:
roidmi 3s dual usb car charger
xiaomi charging set
Product Features:
Guess you like:
xiaomi charging set
