For years a 102 woodsman, and maybe a little trapper or duke folder.
maybe 30 deer, a few elk, 15 or so prongies and few hundred coyote and other fur bearers.
Then for a bit a Vangard. but its just a little too clumsy for me. For me the perfect would be a 7/8 or 3/4 scale vangard. The mini mentor (non gut hook) is a pretty good size, so make a vangard in that size. I really like the mini alpha blade shape, but do not care for the exposed tang mini grip panels. I would prefer a better set of scales on it. I also prefer the older ATS 34 steels to the newer s 30 v. Maybe the newer stuff has some better properties, but ATS 34 is so fine grained that it is far less likely to chip or get a ragged edge than the three S30V blades I own. If you use a buffing wheel or a strop on ATS 34 you get an edge so sharp that it is just flat scary, and it holds up for ages too.
