I'm starting to figure this out.
George and Eric, Thanks a million for the info. I think I'm going to go the route that Bill posted. It's a lot more expensive...but the integral package is really attractive for space ...and it'll be a real time saver for me in setting it up.
$1800 for one of these...yikes! I'm not sure this is what I'm going to do but it sure is convinient. I can just run down the street and pick it up in "will call".
Here's more background on my application.
This press will be used for broaching keyways in KMG wheels, and disks. Currently they are being done by hand in a fancy "H" frame arbor press.
I'm just going to put a hyd cylinder on the press and remove the mechanical gear/ratchet stuff. These broaches are 24" long or so...so a long working stroke is needed. I have a 2-1/2" bore hyd cylinder with a 30" stroke that will be used.
The braoach engineers told me that the braoching tonnage is only about 2200lbs of force. This is much lower than I imagined....and comes out to be about 450 psi at the bare minimum. So a 1200 psi system will be more than enough. A 2 stage pump will be nice for the non-working ram speed...but since my working stroke is so long....24"....I don't want the pump to drop into the high pressure mode while broaching...and slowing everything down to a snails pace. So I'm trying to understand just how fast my ram speed will be at different flow rates.
...back to the books...ergh!
-Rob
