- Jul 8, 2002
Hey all, I think I finally found the solution to the bottom of horizontal forges getting eaten away by flux. I have tried steel, stainless steel, ceramic, porcelin, and "welding brick." All of those either failed (got eaten away) or couldn't handle the thermal shock and cracked.
A while ago I bought a 4 x 4 x 24 chunk of EDM graphite off of eBay. I was going to use it for casting molds before i found my pure nickel bar stock. I ended up giving it to one of my suppliers at work that does EDM stuff. Well, they never used it so they gave it back to me.
I thought I would give a piece a test run in the forge. I heated a 4 x 4 x .75 piece upto orange and put some borax on it. It handled that with no problem. I then took it out of the forge and quenched in a bucket of room temp water. No problem with that either. Then stuck it back into the hot forge and it handled the thermal shock just fine. After that I took it out and let it cool down. After it was cool, I was able to scrape the solidified borax off with my finger nail.
So I cut a 4 x 18 x .625 slab off and milled out a 3.5 x 16.5 x .1875 channel in it for the melted flux to collect in and not run over the sides. The stuff machined beautifully, and I was even smart enough to have the shopvak running to suck up all the graphite dust as I milled.
It was still a bit messy, but the little woman was in bed already.
Anyway, time will tell, but it is looking very promising. The real test will be when i start using the "special" SS flux. Keep your fingers crossed. But for now, it is shower time before the wife to be finds out what i did.
