Looks like they still have them for sale @DLTtrading.I preordered, but haven't seen a thing. Pretty excited for this one.
Nice photo. When I first looked at it I thought I read Buck and then realized it is Buick.At the car wash today
Is it gonna win over your lil native?At the car wash today
LolNice photo. When I first looked at it I thought I read Buck and then realized it is Buick.
Nope, but it is definitely fun and sliceyIs it gonna win over your lil native?
Nice photo! How well does the compression lock work? Is it easy to disengage?Nope, but it is definitely fun and slicey
It is for me. The cutout is a nice size, not as big as the pm2/para 3 but it's good. The comp lock and lock release cutout reminds me of the Mantra 3Nice photo! How well does the compression lock work? Is it easy to disengage?
Be careful the tip is close to the edge of the liners and I have to small cuts on my pinky.
Be careful the tip is close to the edge of the liners and I have three small cuts on my pinky.
Yes it certainly is, if your one who slides your finger along the knife when pulling from pocket I'd advise caution! Just a slight amount of pressure against it when you go in for it is enough to catch that needle like tip.
They better not send one to @NickShabazz he's gonna tear Spyderco a new one on that! It would be especially bad for those with small fingers, I wear 2XL gloves and it does not take much to catch the tip for me.
Love the knife but I can envision a scenario where someone over enthusiastically goes for the Ikuchi, flesh or glove grabs tip, pulls it open and continues sinking in.
Hmmm . . . ????
I had to pull out my Ikuchi to try to figure out what you guys are talking about and these comments don't make much sense to me.
I agree that there is some risk of cutting yourself on the tip of the knife IF you run your fingers along the bottom of the liners where the tip resides when the knife is closed AND if you force the flesh of your finger tip between the liners where it can encounter the tip BUT my question is, Why would you ever do that?
When the knife is clipped in your pocket (or even placed loose in your pocket) either left or right handed w/the knife in the tip up position, your finger would be placed on the top of the knife handle where the flipper dial is located, where you cannot possibly run your finger against the tip because the tip is located on the opposite side of the handle.
Even just handling the knife in a normal way requires you to hold it w/the top of the knife in the palm of your hand w/the back of the blade and the tip facing away from your hand, such that is is impossible to cut your a finger on it.
The only way you would run your finger over the bottom of the liner in the way described is if you placed the knife "upside down" with the clip on the bottom and the closed knife in a tip down position which would be entirely impractical because you cannot open the knife using the flipper dial (or in any other way) if the knife is positioned in this manner.
The only way to open the knife if you pull it out of your pocket with this orientation requires to you first rotate the knife 180 degrees before you can use the flipper dial to open the knife. This just makes no sense to me and sounds like the kind of nonsense people have mentioned about the "dangers" of the Tropen. Both of these knives are entirely safe to use w/o any risk of being cut, if handled in a normal way.
