Update: CRK sent my Impinda back a few days ago. Even though I never held or opened an Impinda I knew right away that this particular knife was not working as CRK designed it to.
Now it opens very easily by the nail nick to start the first stage of opening it. Previous to sending it into CRK one could snap a finger nail with the pressure it took to open it from a totally closed position.
Next is the point where it reaches the 90 degree open where you had to push very hard to get over the hump as the tension spring takes over. Smooth as butter now!
It never was grindy, just a very bindy action at that 90 degree hump.
CRK's explanation for this was not a burr or bent washer. They said non CRK grease or some type of foreign lubricant was built up in the washer holes causing the knife to bind up. When this happens it makes the action even worse not better causing the knife's action to bind up.
I noticed myself that bluish green flakes were falling out of the pivot area my first night opening and closing it, thinking the washers were so new that had not seated or broken in.
I had tried a few drops of nano oil and that helped a little but I could still feel it was not operating correctly.
CRK also said it is not recommended to put any lubricant on the face of the blade that moves on the torsion spring as its not needed and will only serve to catch dirt and wear faster. Makes sense.
Also attached is a pic of their fluorinated grease oozing out of the washers, so it looks like they grease them up pretty good!
I'm a big fan of the Seb 21's and was not really a slip jointer, but this particular Impinda is extremely smooth now as it was designed to be. I highly recommend the Impinda as to its sleekness, beefiness and smooth opening and closing by design.
I even just bought a Ti-Lock "used" which is another slip joint design and its arriving tommorrow.
I really like this Impinda now and I'm glad CRK tuned it up so quickly and shipped it back in just a few days.
Another nice thing about sending a newly aquired CRK knife on various forums is at least I know it was not a counterfit CRK . . . if it was they don't send it back to you
Also regarding the stock overly tight OEM clip . . . CRK bent it back to their OEM position and I was able to once again bend it to just enough light between the clip bump and the handle enough snugness to not destroy dress pants, yet still fit snug and also not to be too tight that it would rip up thicker material jeans. The pic now shows what should be CRK's OEM clip position IMO. TIP: I found using a sharpie cap (the size in the pic) fits over the clip and works well as having something to grip while bending the titanium clip out, yet it leaves no marks like a screwdriver or piece of wood might. If you go too far just remove clip, slide cap back over it and press the other end into a magazine thats flat on a table. Takes a few tries bending it to the best position.
