Recently I broke up the Impinda. That was easy. The assembly went without problems. Interestingly, I found that you can not insert the Allen key in the screw, but use it only on the axis. This is then automatically unscrewed when you hold the screw with your finger in its lowered position in the handle. When assembling, I intuitively proceeded differently: first inserting the axle, then the blade on it and, as a sandwich, the handle on top. (Of course you have to tinker a bit with the washers and the spring and its attachment.) Finally the screw can be drawn in by turning the axle.
Strange that the screw with a groove in the handle is prevented from turning and not the axis. Strange that one has to insert the Allen key into the axle and can’t be used on the screw. The advantage of this construction does not open up for me. Does somebody has any idea?
