Improving the Mora 2000 sheath?
Daniel L
My M2K has just arrived - fantastic knife, but boy is that sheath bad. I don't mind the looks but it does NOT hold the knife securely at all - if upside down the knife just falls out with a slight wiggle.
I pushed it in more hoping for a friction lock - and the tip poked right out the bottom!!! :mad:
Short of getting a kydex replacement (eventually I will) - are there any sheath mods that will make it safer but still relatively easy to access?
dude, look up JRE sheaths on google. You can get kick butt sheath for that M2K.
I HATE mora sheaths. Got a kydex on the way for my triflex right now.
Take care,
Brett
jre rocks for leather sheaths... If you want kydex try Normark from onscene tactical his stuff is amazing.
Likewise on the M2K. Since money's tight (3 kids in school, 1 more getting ready for school, 1 more getting ready to get born, mortgage, grad-school loans), I'm seeing how I can make do with what I've got. So far: boiled some water, poured it through the scabbard to soften it a bit, compressed the sides together until it cooled. Retention problem solved; knife now snaps in securely and stays there.
Tip coming through the bottom: same problem, though it hasn't punched all the way through yet; I can see a crack where it is trying to do so. Proposed solution: I am thinking of plugging the two holes at the bottom of the scabbard with some temporary goop (Play-doh, or even a piece of bread--anything soft and removable, just to plug the holes for a few minutes); then putting some epoxy down there at the inside bottom, maybe using a straw to make sure it doesn't get on the sides, too. I might even try epoxying a thin piece of metal in there. Then, when the epoxy's dry, I'd just drill the holes back through. We'll see if it'll work.
Oh: have also applied leather conditioner to that leather belt-loop; here in the desert, leather tends to turn to dust unless you do that.
I've made a Cody-Lundin-esque basic survival rig with this as the centerpiece. Wrapped the scabbard with 80-pound-test BRAIDED fishing line (not monofilament, but the braided stuff, which actually works like string, and doesn't permanently kink if you wind it around something--makes GREAT compact emergency cordage), with a layer of masking tape around the fishing line to hold it in place. (If I were doing it again, I'd probably masking-tape a couple of fishhooks, a needle or two, and maybe an X-acto blade to the scabbard before the braided-fishing-line wrap--takes up almost no space, but gives you a few more options.) Then stretched a maybe-4-or-5-inch length of bicycle tire inner tube over the bottom of the scabbard, to hold stuff. Then crammed into the inner tube section a Fox 40 Micro whistle, a mini-Bic lighter with a couple of gaskets stretched around it to keep the button from being depressed accidentally, and a couple of firesteels (including one thin BSA "Hot Spark" and one Horseshoe Mountain one, with the magnesium bar). I may eventually put a couple of "fire straws" filled with petroleum-jelly-coated cotton in there, too. Through the belt loop, I've run a length of braided paracord, long enough to hold it, not around my neck, but over one shoulder and under the other arm, so I don't go around with a pre-made noose that can catch on things, etc. Hung onto the paracord loop is a micro Mag-lite that I had lying around; were I doing it from scratch, I'd go for a tiny LED light. Largely, this was just an experiment to see what I could come up with using just stuff I had around the house.
Any pics of the Cody-Lundin survival rig. I've got a 2K that I'm itching to try something with.
I couldn't stand the sheath that came with the 2K. This is the setup I made for it. Its the same sheath I make for almost all of my knives. It's a horizontal carry with a set of holes for a necker setup and a drain hole so it can be flushed out. I also make the sheath with a thumb ramp and grooves so that it holds the knife and snaps in crisp, but all you have to do is grip the handle and push with your thumb to pop it out. The reason that I went with horizontal carry on these is because for me its much more comfortable, keeps the knife out of the way, even when couching down, and if you just wrap the paracord around the belt loops once or twice, booya, you just turned it back into a vertical carry. Usually I just wear it as a necker with a bit of paracord though. Since then, I've also started adding firesteel loops to these. I have to get some new pictures to show them off that are better quality, but this is what they look like. I would suggest finding someone who could make you something like this. Also, I use a slightly lighter thickness kydex than most sheath makers. It's just as tough and doesn't take up as much room and is lighter. I like it a lot more.
Also, Normark (Eric) at On Scene Tactical makes some great sheaths. I have a couple of his. They look like you could launch a missle at them and they'd be fine. The are great quality and the fit and finish is terrific.
Good thinking - will give that a go and if it all turns to custard I'll get an On Scene sheath and put myself out of misery.
As for the bottom of the sheath, I'll just see if I can melt it closed for now.
It wouldn't be that hard for Mora to just mold a couple of dimples into the sheath...
I don't have picture-posting ability, but I got the idea from Lundin's book 98.6 Degrees: The Art of Keeping your A$$ Alive. He uses a standard wooden-handled Mora knife on a neck loop of braided paracord. He attaches a few other things to the Mora scabbard with duct tape, at least some of which is brightly-colored. As I recall, he suggests keeping a firesteel, maybe an un-lubed condom or two (for use as a water receptacle), a flat, pealess whistle, and a Bic lighter taped to the knife scabbard. Maybe also a small flashlight; I forget, and don't have the book handy.
If you're not familiar with his stuff, Lundin is quite worth reading. His two books of greatest interest are the above-mentioned 98.6 Degrees, and the recently released When All Hell Breaks Loose. The former is about how to prevent a little outdoor trip from turning into a disaster, essentially by staying alive for the 72 hours or less it'll take for rescuers to find you. Very little on finding food or building log huts, but a lot on getting seen and avoiding hypothermia or hyperthermia enough to last until the forest ranger shows up.
A very realistic look at what is needed for the most-realistic outdoor-type survival situations.
The latter book, MUCH bigger, is about general disaster preparedness. It also has lots of good ideas.
These books don't go into the "how-to-chip-arrowheads-out-of-flint" stuff like Larry Dean Olsen, nor into the Canadian axecraft stuff you'll get from Kochanski, nor the jungle-hut-building you'll get from Graves. Like probably all survival literature, they are focused on specific kinds of survival under specific kinds of situations.
This is the belt sheath I made for my Mora 2000.
Its sort of an experiment in that I wet molded the leather around the finger-guard area and then expoxy inside to make a snap-fit retention. The knife clicks into place and is very secure. Mac
got my 2000 by frosts today too, lovely knife!
i wrapped the sheath with a few meters od OD paracord, tightening it hard it became better
looking for a better sheath though
I just got 2 Mora 2000's and had Normark (Eric) at On Scene Tactical make 2 sheaths with swedish firesteel loop's and they are sweet! (Thanks Eric!)
I just did a "cheap" solution by gluing in a thin strip of rubber mat inside the sheath. Knife is very secure now :)
Also put the lighter flame on the bottom where I accidentally pierced the sheath and pushed it together - it melts easily and is now sealed so I feel a bit safer about it.
