Well it was the MIG that arrived today, which is fortunate because I don't have a bottle of Argon right now anyway. Just 75/25 mix. I unboxed it, plugged in the whip, connected my bottle, plugged it in to 120v because I don't have the same 220v outlets as the plug it came with (30a, 2 flats and a round, I have all 3 flat dryer outlets), set the gas and started welding.
My initial impression is holy s&$^T! I didn't think you even could weld this well, this easily with a 120v MIG. I've had this Century 130 for 23 years since I was 16 years old. It's
never welded like this thing. I've made it work, and I can weld damascus and rebar with it, but it's not easy to do and it's incredibly slow going.
Here's the new 200e. No bells or whistles, just infinitely adjustable voltage and wirespeed and a connection for a spool gun.
Here's welding rebar to the end of a billet I had laying around:
Here's breaking that rebar off. The rebar bent this far, then the base material failed as it should. It's high carbon and as the weld shrank it put a lot of stress on the joint. If this had actually gone into the forge a couple times I doubt I would have been able to just snap it off.
Here's a canister, notice how nicely the welds tied together at 2 o'clock? Impossible with the Century. They'd just lay on top of each other no matter what you did.
Here's some 1/4" thick mild steel. Fillet on both sides. Then I cut it and macro etched it to see penetration. It's not great, but again this was .030 wire on 120v and I think I could do better with a little weave.
So my initial feelings about this $500 inverter MIG is it's god damn awesome and I haven't even plugged it into 220v yet. I bet the TIG will leave me feeling the same. I'll update when it arrives.
