- Oct 11, 2013
First of all, thanks to fellow Bladeforums member
abbazaba
for a tremendous deal on this Smock, as I've been wanting one of these for some time, but the timing never seemed to work out. Well, thankfully it was finally "my time", and so here we are!
I've gotten the knife in and have carried it for a day or so, and some things jump out at me immediately as being both good, and maybe not great on this knife. I won't say "bad" because this is truly an excellent knife in my opinion. I'm glad to have it. Let's run down both the Good and the Could Be Better, shall we?
I'll put the "TL;DR" up front: Ultimately, I like the Smock, like, REALLY really like it. It has a flaw or two, but overall, I'm glad to have it and will definitely be carrying this one.
The full version:
Good:
Could Be Better:
Overall, it's a great little knife, and definitely one of those that'll be sticking around. Onto some pics I took today:
The full version:
Good:
- - It's slim and light, makes a perfect EDC knife, especially in perhaps less-than-visually-permissive environments (I work in an office space setting). Slips into a pocket and totally disappears.
- - The edge as it comes from Spyderco was screaming sharp, and the grind seems respectably thin behind the edge (no calipers, so no measurements).
- - The fit and finish are perfect, and exactly as expected from a Taichung Spydie.
- - The button compression lock really is good, because it allows me to depress the knife and swing it closed like an Axis lock knife. This makes for quick in & out cutting and repocketing at need.
- - I love, love, love the blade shape. I just love wharncliffe type blades. I use my knives primarily to eat, open mail, and snip off threads, and this knife excels at those roles (did all those things with it last night, actually.)
- - The scales actually have an element of grippiness to them, which is good, because this knife definitely needs it (goes hand in hand with a con below).
- - I really like the flipper tab's placement. That is just a great design feature. When tabbed properly, it flips open just fine. It's not bearings-fine, but serviceable.
Could Be Better:
- - It's a tad small. This knife is roughly the same size as a Spyderco Delica. I'd love for this knife to be just a hair bigger. Of course, I recognize that if it were, it'd probably suffer a hit to the first pro listed above. As is, this is much more of a gent's sized knife rather than a work-sized knife. So, bear that in mind if you're looking at this guy.
- - The finger choil is not in the best place if you have large hands. It needs to be moved up a centimeter or so, or else eliminated entirely. I DO understand why it's there, and like that it allows actual, functional access to the Spyderhole, but still. I find that I use my middle finger in the choil, and the index finger rides on that blocky section just above it. That said, a full handed grip IS possible if you choose to hold the knife with your index finger in the choil.
- - The flipper tab needs, needs, NEEEEEEEDDDDDDDDDSSSSS jimping on the top. Aesthetically the smoothness works because there's no jimping anywhere else on the knife. I get that. But there were a few misfires until I got the hang of it. If your hands are wet, or whatever, it's easy to have your finger slip right off the tab. I am going to fiddle with it some more and get some muscle memory going to see if that helps. The detent IS fairly strong, so you can't flip or even deploy the blade if you don't mean to.
