bigolegator
- Mar 26, 2014
Could you post pics in hand or similar?I got mine in. Perfect centering and lock up, though I had slightly loosen the pivot a tad to get it to move a little more freely when the lock is released. I didn't loosen it enough to be a free swinger, just enough so it doesn't take undue force to get it to move with less effort.
The edge is .020" thick at the top of the bevel, and it's about 13-14 degrees per side. Not bad, but I will probably end up thinning it out more. Either way it should slice great for a factory knife with that geometry and thin blade stock. It is sharp enough to pop some hairs on my arm, and the grind lines look very even. No recurves or other funky stuff like I've seen posted about lately.
The handle is just large enough for me to fit my whole hand on there by keeping my fingers close together. The ergos aren't great, but they certainly aren't bad at all, especially for a knife that prioritizes slimness and lightness. The handles will now in a bit if you squeeze them, and maybe another stand off in the middle of the knife would help that, but then again it would cost weight. The clip is great for low riding the knife in your pockets, with good retention. The knife works perfectly clipped to my gym shorts and gym pants, as I hoped.
I'll have to do some cutting with it to get a real feel for it. It should be a very good light duty folder. It will probably be able to handle many tasks, but the handle flex might reduce your confidence for some types of cutting. I'll have to grab some pine and see how it does making some feather sticks. I would rarely use this knife for that, its more of a gym or dress carry knife for me, but it would be good to know it could handle that work without worrying about the handle flex causing any issues with lock stability. I highly doubt there will be any issues with that, though. The inside of the scales may be a little sharp and create hot spots on heavier cuts. I'll have to see later when I actually get to use the knife.
