Irwin visegrip multi pliers
Just picked up an irwin multiplier with the fold out knife and screwdriver, the model is 5wr. I am guessing its going to be like a poormans leatherman crunch, minus the ability to fold. Anyone have any experience with these things? I only paid like 8 bucks with shipping so my plan is to throw it in my glovebox just in case. Il update the thread when it comes in to tell you guys how it is.....
I'll be curious to hear how it performs. Seems to be a huge design flaw that the blade deploys out the front, where the plier jaws are in the way, instead of out the back. What were they thinking? And it's too bad they seem to come only with a partially serrated blade. :(
Hmm, it does look a little awkward. Though the blade opens in the other direction, it makes me want to say "Knife-Wrench!". Should be neat to play with though and $8 isn't bad.
Definitely a two hand opener, but I like the concept. Should be no question about the Vise Grip itself, just wonder how using the other tools work out.
I saw them when they came out at lowes, after playing with one I feel like it was a good idea poorly executed. The blade opens to the front with the pliers head in the way.
Yup.
At the Multitool forums there's been quite a discussion about these. A long one.
They're the typical novelty, throw in the toolbox stuff.
Irwin tried resuccitating the Vise grip multitool idea (as most Vise Grip MTs are discontinued, from Kershaw's A100 to the different collabs between Schrade and Irwin) once Schrade went down and their locking pliers multitools lost forever.
I am a true fan of the old Schrade Grips (being the original 5WR one of my most common carried multis), but the newer ones are purely novelty tools.
Nowadays, one looking for a vise grip multitool can only go Crunch/Gerber grappler to make a decent purchase...
So sad!
Wow, i never thought there was such a history on these things. Im still waiting for it to come in, i was thinking maybe it could go in my firefighting coat to eliminate the plain visegrips and screwdrivers that i usually carry. Most of it is already covered wi my leatherman oht but i like to have some redundancy just in case something breaks on a call. Im guessing the knife wont be replacing much of anything i already have just based on how it looks in the pictures.
Well i was thinking about taking pictures and posting a review of sorts on this thing, but its really not worth the time.
Heres the long story made short.....
The knife is a liner lock. Who knows what steel it is, but it is partially serrated 3 ish inch (the plier jaws kind of pertrude into your cutting edge) and is decently sharp out of the package. I had to fix the side to side play with the hex screws that are on it, but so far it seems to be tight. The fact i was able to actually service the tool to get it in shape is a plus. Weird ergos when open, could be a one hand opener but it's ackward. Its really just kind of a crappy knife screwed to the side of a vise grips. A positive thing about the knife is that it appears to have some sort of bronze or brass washers.
The vise grips are small. Basically a small vise grip with wire cutter in the mouth. They function as they should though the size prohibits using them for most jobs calling for a vise grips......best way i can put it. They do not have the release lever , but i think they all have an auto release feature now. It worked great on a half inch hex nut on my sons scooter.
The screwdriver folds out of the bottom of the handle. It comes out by way of a notch and a nailnick of sorts. It "locks" open and closed with a detent ball! This was a surprising feature as the knife was so underbuilt. It comes with a reversible bit that has a number 2 phillips and medium sized flat head. The screwdriver feature has a hex driver , but the bit that comes with it doesnt lend well to using other bits in there. Using it as a screwdriver is uncomfortable and you need alot of room to actually be able to make full turns. Opening the pliers up does give you a bit more leaverage .
Rather than go into great detail about the tool im just going to leave it like this.....
Its worth 8 bucks which is what i paid. Its a good first multitool. I cant see many instances when this tool will be used over any of the other things i already have. Its the type of thing that if its all you have on you then you can make due. It's exactly what it looks like- A small visegrip with a knife attached to the side and a screwdriver shoved into the only place it would fit. Though made in china it does have a lifetime warranty, which for me makes it worth much more than most crap in this tools price range.
Owning this "multitool" really helps you to appreciate the thought ,engineering and constant refining of companies like leatherman who have revolutionized pocket tools into something we take for granted. If you dont want to shell out like 90 bucks for a crunch this little guy may be a good option.
For sure a different animal. The old ones are built like a tank and are also bringing quite a pretty penny on the big auction sites. Hang on to those tools my friend, that is quite the collection you have.
