- Jan 24, 2021
does enyone know if dialux compound is good enough to sharpen a straight razor if so which colour
All right cheersI've got some of the green coming on Monday or Tuesday, and I'll report back then if no one has gotten back to you.
CheersAlright, Green (Vert) Dialux came in the mail and I've tried it out on a hollow grind. 10 strokes on either side on a pine strop, and it's shaving much cleaner than before and push-cutting paper with no problem. I know you already got your answer, but I can second how well it works.
It came in a solid condition with no flaking. It is not oily, and is very firm. I kept it in my front pocket to heat it up a bit; ~10 minutes later and it easily rubs into the soft wood. I have heard that there are some fakes out there, and I can confirm that the real stuff is a deep forest green with no brown or off color spots.
Good luck with your razor.
I haven't tried stropping with paste yet to finish my razors. I'm curious what you used to finish prior to using this paste?Alright, Green (Vert) Dialux came in the mail and I've tried it out on a hollow grind. 10 strokes on either side on a pine strop, and it's shaving much cleaner than before and push-cutting paper with no problem. I know you already got your answer, but I can second how well it works.
Ok I understand why the paste makes such a big difference for you now, coming off a 1000 grit stone.I start on a King 300 stone; then I switch to either a Spyderco Medium or Shapton Ceramic 1000. Then I strop with Dialux. I'm kind of blown away by how sharp it gets and the mirror polish. I figured I would need to finish on a 5000 or something before stropping, but I guess not. Maybe I'm missing something.
Just my opinion, you need at least 2 more stones after the 1000.
I think I'm one of the few who prefer an arkansas progression, and maybe the only one that inserts a spyderco uf before the final black ark. Most use the standard 1k/4k/8k/12k synthetic then leather.That's good to know; I figured I was cheating. Guess I still need to invest in a 5000 or something. At some point, I'd like to spend some money on an entire Arkansas set.
Thank you.
try a ~4k after the 1000 and before paste. Maybe later add an 8k.
Jave, I've given you my best recommendation based on limited experience, knowledge, and experience. There's a majority of people with decades more experienced with straight razor sharpening and shaving that disagree with me. I highly recommend browsing dedicated shaving forums, digest what's there, and choose your own way.Cool, thanks for the breakdown of your system. I really enjoy the feedback and durability of my Hard Arkansas pocket stone, so I hope to expand to a full set at some point. Arkansas stones are classic.
I've seen reference that charnley forrest stones are novaculite, like arkansas stones. Does that sound right? If so, what grade of arkansas stone does your charnley most act like?I don't work my blade on a lot of stones. When it needs tuning, I'll take it to my Charnley Forest stone or my Belgium cuticle stone. And work it on those. I have those other stones, the black Arkansas and a Spyderco ultra fine ceramic. All good stones. I resist that much stone work. Then I strop on leather with the green Rouge applied.
Razor sharpening is one area of sharpening that it's acceptable to get OCD on.
Still, I get a good shave. DM
