Is it possible to convert a bench grinder to a buffing machine?
It's very simple. Buy a buffing wheel of the same shaft size as the grinder. Remove the hood from the side of the grinder you want to put the buffing wheel on. Unscrew the lug that holds the grinding wheel in place. Remove the grinding wheel. Assemble and install the buffing wheel. Tighten the lug down to hold the wheel in place. Voila... you're done.
I did it about a year ago on my Craftsman 6" bench grinder. Works fine, on the very rare occasion that I use it as a buffer.
Yea, u would have to make some shaft extensions, also you need to make sure it has enough power to do what it needs to do...
Here's a picture:
Works OK but be Aware of those Soft buff disks...Grabbed my Opinel and threw it 15 feet behind me where it Stuck in the wall. An eye Opener for sure!!!
There are basically 2 ways of doing it.
As Trippyr says, one way (the cheapest) is to remove the guards, run a suitably-sized drill (usually 1/2", but maybe something else-it depends on the grinder spindle) through the centre of the buffing wheel and mount it instead of the stone. Sometimes you'll find the washers on your grinder are stepped and will not accommodate the thickness needed for a buffing wheel. Large diameter flat washers of the right ID will usually fix this.
The other way is to buy pigtail adapters to screw onto the spindle; you'll need to make sure you get the correct theads. Bear in mind that one end has a left-handed thread.
The first method makes it a pain to change mops, but keeps the loads in close to the bearings. The second method makes changing mops easy, but gives a lot of overhang. Neither is ideal. I went the first route myself, since I'd not be particularly comfortable adding pigtails and overhang to a cheap grinder, built down to a price, with already-marginal bearings. If I used a buffer much, I'd spend the money on something designed for the job.
As an aside, I didn't have to drill anything. The buffer wheel kit (either from HF or Sears, I can't remember which) was already set to fit my shaft size. It was as simple as taking the grinding wheel off and putting the new buffing wheel on.
Somebody gave me a herkin one horse grinder years ago, now that I have belt sanders around it never gets used- I don't want to just put buffing wheels on it because the body of the motor is so bulky.
Thanks for the reminder about the tapered spindles, we used to use those for silver work. That would give a little room to work around the buffer.
